NI 488.2 and NI VISA problems on win 10
I'm having problems getting my NI GPIB hardware operational on Win 10x64. This hardware worked fine previously on win10x64, but I had to reinstall the OS as my disk died. I took the opportunity to download & install the latest NI-488.2 v17.6 & NI VISA v18 from the website. I installed both these (can't remember which order I installed in), but could not see the drivers loaded properly in device manager. Re installing the NI-488.2, I get a message saying that the NI-488.2 Runtime 17.6 (64 bit) installation has failed.
I uninstalled everything using remove all button in the NI manager & installed NI-488.2 version 17 which I was previously using before I had to replace my disk. I get a similar message. Any ideas? Its driving me nuts.
The GPIB hardware is a PCI NI card, but I've also tried with a GPIB-USB-HS with the same result. Apart from the error message indicated above, the drivers don't install.
Thanks for any help on this.
Joe
(4,465 Views)
Generally when you re-install Windows 10 you need to install the drivers starting with the chipset.
Always the case with the PCs I have from Dell, HP, Lenovo, Acer.
good luck
(4,449 Views)
The only stuff showing driver problems in device manager are my NI products. These are my PCI-GPIB card, my DAQ card and a GPIB-USB-HS (bought from NI) when the latter is inserted. I've not tried to install DAQmx yet, thats a 2Gb download....
All chipset stuff, sound, graphics etc are fine.
Joe
(4,447 Views)
Joe
If you say so.
(4,428 Views)
Hi Joe,
Is the hardware itself appearing in either device manager or NI MAX? It may be a case of pointing windows towards the correct driver for
the hardware if it is trying to use a generic driver. Alternatively you can try to force reinstall the software you believe is causing issues.
Jonah W.
National Instruments.
(4,415 Views)
