NI 488.2 can support VS2013?
I have add reference "NationalIstruments.NI4882", but can't coding 488.2 command. please see below picture.
My OS is WIN 7 64 bit, VS2013, MAX v15.0.0f0, upgrate to new version.
Below is my code, can't to build, NI488 code can't complete compile.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Ivi.Visa.Interop; //VisaComLib
using NationalInstruments.NI4882;
using NationalInstruments.VisaNS;
namespace xxx
    class Program
      private MessageBasedSession mbSession;
        static void Main(string[] args)
          int noncontroller;
          char[] buffer = new char[100];
          int panelHandle;
            //Open  session to the GPIB board
            noncontroller = ibfind ("gpib0");
            //Release system control
            ibrsc(noncontroller, 0);
            //Change GPIB primary address from 0 to 2
            ibpad(noncontroller, 2);
            while(true)
                //Update status variable
                ibwait(noncontroller, 0);
                //Wait until non-controller is listener and ATN line is dropped.
                if ((ibsta&LACS)&&(!(ibsta&ATN)))
                    ibrd(noncontroller, buffer, 100); // Read data bytes
                    buffer[ibcnt] = '\n'; //Add linefeed and 0 to string
                    buffer[ibcnt + 1] = 0;
                    Console.WriteLine("Buffer Value{0}", buffer);
                    //printf("%s", buffer); // Print buffer for C
                    return;
Message 1 of 12
(9,946 Views)
If you the newest NI-488.2 installed, it should support .NET Framework 4.5.1
Message 2 of 12
(9,931 Views)
Yes, can support .NET Framework 4.5.1, so only can use .NET to programming?
Message 3 of 12
(9,909 Views)
I don't understand your question.
Visual Studio uses .NET
Message 4 of 12
(9,892 Views)
I think loss NationalInstruments.Common,but add reference, can't include program, please see below picture.
NationalInstruments.Common verison is 15.0.40.49154
.Net Framework 4
Message 5 of 12
(9,882 Views)
Confirm NI4882.dll is working, but can't use ibfind,ibwait..... command, i don't know why?
Message 6 of 12
(9,872 Views)
You set a reference to the GPIB .NET library, but you using the old Win32 function calls.
ibfind, ibread etc...
You need to use the NI488.2 Class library objects and methods
Check the examples located at the followng link
https://www.ni.com/en/support/documentation/supplemental/18/ni-daqmx--ni-visa-and-ni-488-2--net-exam...
Curt
Message 7 of 12
(9,752 Views)
Thanks and understood, but use .NET library, any document can read, because for Win32 have NI-488.2 user manual for reference to programming, such as ibfind,ibwrt...etc, but .NET only example program, i don't know which command same ibfind?
Message 8 of 12
(9,708 Views)
I think find maybe answer,please see path http://zone.ni.com/reference/en-XX/help/370628F-01/mstudiowebhelp/html/gpibapimapping/
Message 9 of 12
(9,705 Views)
Accepted by JackieLin
You need to create a Board object.
Address boardAddress;
        Board board;
        private void butOpen_Click(object sender, EventArgs e)
            bool retval = false;
            try
                boardAddress.PrimaryAddress = 0;
                board = new Board();  //defaults to 0 for GPIB board index number 'GPIB0'. Change to your board number idf required
                retval = board.FindListener(boardAddress);
                Debug.WriteLine("FindListener returned " + retval.ToString());
                board.IsSystemController = false;
                retval = board.IsSystemController;
                Debug.WriteLine("IsSystemController returned " + retval.ToString());
            catch (Exception ex)
                Debug.WriteLine(ex.Message.ToString());
Debug Output
FindListener returned True
IsSystemController returned False
Good luck!
Curt
Message 10 of 12
(9,698 Views)
