NI-488.2 installation on Windows 10
NI-488.2 V15.5 or newer can support Windows 10, however the previous release e.g. V14.0 can install on W10 as well. Furthermore the new version cannot be installed successfully if the previous version is not uninstalled. Then how to uninstall the previous version via command line? The installation was called by "Setup.exe Spec.txt /q /r:n".
Thanks in advance.
Message 1 of 1
(2,829 Views)
