NI-488DDK LINUX
Has anybody converted this package to compile under linux?? Last entry on the change log was Jun 02.. I think this was the bases for NIGPIB-0.8.2 pack, which did NOT include source code for the ni-ib.o portion of the driver module... I could use a copy of the makefile for it. In the mean time, I am starting work on developing one!! If anyone else is in the same trouble, as myself!!
(3,359 Views)
Update Info: I have two (2) PC/104 cards running, I think, under LINUX 2.4.18. I have the DDK kit and have a TAR ball of IBCHAT program which Bangs away on the GPIB bus between two diffent cards, ie. devices. I have one PC/104 chatting with the other, in two seperate processes. But the displays are very confussing.. and NO docs as to "How to Run this program". Sure, there is a "-h" option, but not very helpful.. Some enlighten by the NI folks would be helpful!!(Hint..Hint..) Unless they have that LOCKED up too!! (so much for GPL)
(3,359 Views)
