NI-568x serial link commands "TRGIMM" etc
I am using a NI USB-5681 power sensor with python. I know you can use the ni568x_64.dll with ctypes and this works but this is a very clumsy method.
If I monitor the USB bus I noticed the USB-5681 acts as a serial device and you can talk to it through the serial link using pySerial.
The following python code reads the power measurement using the serial interface
import serial as s
from time import sleep
ser = s.Serial('COM10',timeout=None)                                          # open serial port
ser.write(b"IDN?\n")
print( ser.read_until('\n'.encode('utf-8')).decode('utf-8'))
ser.write(b"RST\n")
print(ser.read_until('\n'.encode('utf-8')).decode('utf-8'))
ser.write(b"START\n")
try:
  while True:
    ser.write(b"TRGIMM\n")
except KeyboardInterrupt:
  pass
ser.close()
Please can you give me a link to the user manual for the NI-5681 RF POWER METER serial commands. The NI website seems to avoid the subject.
MPC.
(590 Views)
Reverse engineering is probably the only way to figure out the commands, as NI officially recommends using the 568x only through their NI-568x driver and not through VISA or serial.
If you are motivated enough, you can use the Soft Front Panel, monitor the commands, and create a map between the various SFP operations and commands.
Santhosh
Soliton Technologies
(549 Views)
