NI 9146 as modbus slave ?
Is is possible to configure a NI 9146 ethernet expansion chassis as a modbus slave ?
(4,196 Views)
Hello ppberube,
You'll need to add a controller to your NI 9146 to turn it as a RT Target. Then, install DSC module. Please check this link.
CC
(4,181 Views)
Thank you very much for answering, it confirm that i need a Controller, not only a Expansion chassis, because it needs to be a RT target in order to be set a modbus slave.
Best regards !
(4,178 Views)
