NI 9188 and CompactRIO chassis
Hi!
Currently i need a cRIO system that can interface with DELTA ASD-A2 servo drive controller. So, i need a CANopen interface onboard my cRIO. While searchig NI hardware i've found a NI-9881 CANopen module. But in the requirements tab i see "module requires the NI cRIO-911x/906x/908x chassis". And i have a 9073, 9074 and 9075 chassis. Why not use the integrated chassis and controller for NI 9188 (i guess, there is some serious reason for that)? Or maybe NI-9188 module will work with new integrated controller/chassis (9075/9076/9074)?
Any help will be appreciated.
Thanks!
(4,814 Views)
Hi Slava_R,
I can't speak definitively to why the NI-9881 in the cRIO-907x chassis, it likely has something to do with the capabilities of the FPGAs on those chassis. I can, however, confirm that you do indeed need one of the supported chassis (911x/906x/908x) in order to be able to use the module.
I've linked a document below that discusses other CANopen options in case you're interested in alternative solutions.
What CANopen Software is Available and What Hardware is Compatible with National Instruments Products?
http://digital.ni.com/public.nsf/allkb/13C3CB1148A2AEA4862579DB0066E66B?OpenDocument
Ryan K.
Product Manager, ATCA and BEEcube
(4,786 Views)
Thanks, Ryan, I'll check the attached link.
(4,770 Views)
