NI 9871 Bias Resistors
Yes it was set at 9600 baud.
I assume you don't put the 390 ohm resistor between the Vcc of 24v for the module and the Tx/Rx+ line? That would bring the Tx/Rx+ line too high?
The other device is an Adam 4570 RS485-->Ethernet converter.
http://www.advantech.com/products/ADAM-4570/mod_44434F5A-C264-41B2-844C-A3FC63082E5A.aspx
Message 11 of 17
(1,805 Views)
No, Vcc is 5V (or 3.3V) the power voltage of the RS-485 transceiver IC.
Is the data at the video from both devices ?
Message 12 of 17
(1,802 Views)
Without opening the module and modifying it I won't be able to fit that resistor, which I why I'm confused, surely the module should already have those fitted to conform the the spec?
The data in the video is just the 9871 sending. The adam module sent this.. https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn1/942817_821399569387_1496657446_n.jpg
I didn't video it as it didnt change.
Message 13 of 17
(1,797 Views)
How did you connect the scope ? Tx/Rx+ and 0V ?
Message 14 of 17
(1,793 Views)
Between Tx/Rx+ and Tx/Rx-
Message 15 of 17
(1,787 Views)
Did you solve the issue? If so - how?
Message 16 of 17
(690 Views)
This thread is 10 years old !!
I think it is better to create a new thread and describe your problem with enough information.
Kees.
Message 17 of 17
(685 Views)
