NI DAQ interactions with a temperature control unit
Unfortunately, I will not be able to provide a screenshot or exact data. But here's the issue. We're needing to run a 5V PWM from an Arduino uno r3 through a Wavelength Electronics PTC K-CH 5. When hooking up the DAQ to the unit it's been reading as a certain voltage equivalent but once disconnected and reconnected, the value changes, any suggestions? When checking online, the most frequent solution has been an RC Filter.
(4,268 Views)
It mentions that you need to have floating power sources; otherwise, it can affect your readings.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,220 Views)
i had similar issue with one my blog i could not able to find any support for the issue so i left. i hope this post would have been there at that time.
I hope this post would help other to sort things up
(4,199 Views)
