NI I/O Trace - set the options for all user
Hello!
I'm using the NI I/O Trace on a PC-System.
The idea is to let it start together with windwos (autostart) for all users.
The problem is that the settings I make with useraccount "x" will not be set for useraccount "y".
Is there a solution that makes settings for all users effective?
(4,749 Views)
HI CDM_Na,
I think that the easiest way would be to put a shortcut of the "NI IO Trace.exe" in the folder C:\Program Files (x86)\National Instruments\NI IO Trace (if you are using Windows 7)
With Windows 7, the startup folder for all users is: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Marc
(4,716 Views)
Hello Marc and thank your for your reply.
The automatical startup of the program is already working, so that is not actually a problem at the moment.
I do have a bit of trouble with every user having the same settings made without me logging into every account.
Chris
(4,707 Views)
