NI-IMAQ interface error
I am using NI-DAQmx for first time on a system already previously set up / installed.
I keep getting a this error.
-1074397163
While running an IMAQ-Vision example in LabVIEW 5.1, I see this message: Error -1074397163 occurred in Cleanup module.
This error is generated when the IMAQ Init VI is called with an incorrect interface name. In MAX, the NI-IMAQ driver assigns an interface name to each IMAQ board in your computer, starting with img0, then img1, etc., in the order in which the boards are installed. If for example, MAX has img1 set for your interface and then in your code you call the IMAQ Init VI with the interface name img0, it will give you this error.
The NI-IMAQ driver has assigned img0 as the interface name (I can check this in MAX), however I don't know how to check or change in my code the IMAQ Init VI to make sure this is img0 also.
Would appreciate some assistance.    Matt.
(3,693 Views)
I'm having the same problem , did you solve your problem ??
thanks
(3,600 Views)
