NI MAX Bus Monitor-% used ?
Is it possible to display the % of Bus being used in the NI-MAX ?
I'm trying to create a situation for High BUS load and I would like to see what percentage of the BUS is being used.
With the NI-MAX using the BUSMonitor program -Bus Statistics only gives Frames/second.
Any ideas how I can monitor the Bus load?
-Vamshi Ainapur
Message 1 of 17
(6,283 Views)
Hey Vamsi539,
The bus load percentage should be shown at the top-right of the bus monitor window.
Thank you,
Ryan
Message 2 of 17
(6,249 Views)
Message Edité par JB le 12-01-2008 03:34 PM
Message 3 of 17
(6,247 Views)
Hey JB,
            I Cannot see the Bus-Load option on the MAX I'm using.I'm using Version 4.0.0.3010 for the MAX.
-Vamshi
Message 4 of 17
(6,221 Views)
The screenshot is from MAX 4.5. Your version is no longer installed on my machine.
Message Edité par JB le 12-02-2008 05:03 PM
Message 5 of 17
(6,211 Views)
You should upgrade your version of NI-CAN, this will also upgrade your version of MAX.
Once the upgrade is complete you should now see the Busload percentage whenever you open the NI-CAN Bus Monitor.
Let us know if this helps.
Christian A
Message 6 of 17
(6,206 Views)
Hello Christina,
                         I was checking with another PC that has a different version of the NI software and yes it shows the bus load.It has  NI-CAN (version 2.5.2f0) and my pc has 2.3.1f1.
Can I  upgrade to 2.5.2f0 free of cost ? Where can I find the newest software on the Ni website?
-Vamshi
Message 7 of 17
(6,182 Views)
You can download the drivers free of charge from our website.
Please goto our main page www.ni.com
Click on Support and Community, then Drivers and Updates
In the search within results field type in CAN
now you can download the driver and install, you will need to sign up for an NI.com profile before you can download any drivers.
Thank you.
Christian A
Message 8 of 17
(6,172 Views)
Thanks Christina...that worked!
-Vamshi
Message 9 of 17
(6,133 Views)
I have a simular problem and that means that via the Busmonitor application I also do not see any busload indication anymore.
It has worked, but at some place in time it stopped working.
I re-installed the latest MAX software but nothing helped... It is very important for my work, so can you please help me?
Thanks, I added the system information for info.
Hermen
Operating System(OS)                  Microsoft Windows XP Professional
OS Version                            5.01.2600
OS Info                               Service Pack 3
Processor                             Intel(R) Core(TM)2 CPU         T7400  @ 2.16GHz / x86 Family 6 Model 15 Stepping 6 / GenuineIntel / 2163 MHz
Number of Processors                  2
Physical Memory                       1,99 GB of RAM
Drive C:\                             3,47 GB of 37,1 GB free
National Instruments Software:        Version:
NI-CAN                                2.6.3f2
CVI Run-Time                          5.500.4.0
LabVIEW Run-Time                      8.2.1
Measurement & Automation Explorer     4.6.0.49152
Measurement Studio                    Visual Studio 2005 Support - See individual versions below.
     DotNET
          Common                      8.7.20.131
          MaxConfiguration            8.9.20.111
Measurement Studio                    Visual Studio 2008 Support - See individual versions below.
     DotNET
          Common                      8.7.35.131
          Common (64-bit)             8.7.35.131
          MaxConfiguration            8.9.35.111
          MaxConfiguration (64-bit)   8.9.35.111
NI-PAL Software                       2.4.1
NI Spy                                2.6.0.49152
Message 10 of 17
(4,796 Views)
