NI-PAL 1.9.3f
I have a system that has VISA 3.3.1 & NI-VXI 3.3.1 which in turn has NI-PAL version 1.9.3f
Unfortunately, I don't know what media this version of NI-PAL has come from.
If I load VISA 3.3.1 from the NI web-site, it puts a later version on.
Can any of you tell me which media (Package and part number) would put NI-PAL Version 1.9.3f on?
Thanks!
(3,428 Views)
Hi Brian,
Why do you need this particular version of NI-PAL?
It will be installed with NI-488.2 version 2.4 which can be downloaded from:
http://digital.ni.com/softlib.nsf/websearch/1DDE5C48F30C2C658625702000681295
Regards
Jon B
NI UK & Ireland
(3,414 Views)
Jon,
 Thanks for that. I did eventually find it with the Switch Executive version 2.1 as well.
We unfortunately have an intermittent problem with a VXI Technology SMIP switch which seems to work OK with VISA 3.3.1 & NI-PAL 1.9.3f but not with any other later versions of VISA. (It may also be an interaction with TestStand 3.5, since a standalone CVI 8.0 program works in all situations.)
Again, thanks for taking the time to reply.
Brian
(3,409 Views)
