NI PCI-1426 Library and Drivers
Sorry in advance if this is not the correct location to post this in.
I'm trying to install an NI PCI-1426 frame grabber and I'm getting a complaint from my app that the SDK and library aren't installed.
I've tried installing the NI-IMAQ package, which the documentation for the 1426 calls for, and the device was able to properly install the drivers, but I'm failing to find the library and SDK for this device. Are these still available anywhere?
Thank you!
(2,555 Views)
Hi ,
The SDK is freely available from MSDN at http://www.microsoft.com/downloads
Did you develop your application of Visual Studio?
(2,526 Views)
