NI PCI-485 Baudrate (250kBit/s)
Is it possible to run the NI PCI-485/2 with 250kBit/s
Thanks for any information.
Mario
(3,073 Views)
Currently the hardware supports both 460.8k and 230.4k. All baudrates within 1% of these values are
supported, since successful communication can still occur if you're off by as much as 2% (1% for each partner). One option is to use a custom oscillator value. Instead of the 7.3728 Mhz Oscillator, you can use a 8 Mhz Oscillator. Thus when you set the baudrate to 230.4k programatically, the hardware will operate at 250k.
(3,073 Views)
