NI PCI-5122 Windows 10 Driver
With the demise of Windows 7, does anyone know if there is a driver for  Windows 10? I have installed Windows 10, the NI PCI-5122 is seen in Device Manager and is listed as PCI Device. When I try to install the older driver taken from Windows 7, I receive an error saying that the driver could not be loaded (corrupt or missing) with a Code 39 error number?
I have removed antivirus software aswell, same issue when I attempt to install the Win 7 driver?
Anybody out there have any ideas? I cannot find a newer driver anywhere.
(3,938 Views)
Did you update all the drivers for your model PC?
Try installing the driver in Compatibility Mode.
(3,851 Views)
Thank you for your suggestion. I will look into whether this will be possible.
(3,699 Views)
I did not use compatibility mode. I managed to get Windows 10 to detect the driver it needed within Device Manager - Scan for Hardware Changes and the Update Driver. If I recall correctly I selected Browse for Drivers on your Computer and then selected Let me pick from a list of available drivers available on my computer. I scrolled down until I found NI entry. Windows 10 actually installed a driver NI USB-9162 USB Carrier. The desktop is being tested at the moment to see if it works as it should.
Thank you for your suggestion though.
(3,186 Views)
