NI-PCI 8431
I have a problem of writing frames with fixed frequency 200Hz(5mS) using the NI PCI-8431/2  and  LABVIEW 2013.
I cannot get frames with constant frequency 200Hz(5mS). The frequency is changed during communication.
Why?
Please open enclosed vi and scope picture from the port output of the NI-PCI-8431.
Thanks.
Message 1 of 19
(7,465 Views)
You have a baud rate of 1Mb. What do you mean by a frequency of 200 Hz?
Message 2 of 19
(7,452 Views)
I want send 16 bytes(in this case 16"1")  -  this is my frame - with constant period of 5mS (200 Hz).
Thanks.
Message 3 of 19
(7,446 Views)
Are you talking about the wait function in your loop? That is not at all deterministic on a Windows os. You would need a real-time os to send this.
Message 4 of 19
(7,443 Views)
Ok.
But the time cannot change so : 5mS,10mS,20mS... Please take a look to the picture from the scope.
I can change the While Loop to the Timed Loop,but  I will have the same result.
Thanks.
Message 5 of 19
(7,436 Views)
Of course it can change. The time between iterations will be a minimum of what you set because between iterations, the os will be doing whatever it wants to do. That is strictly a function of a multi-threaded, non-deterministic os. A timed loop is no better. It has nothing at all to do with LabVIEW. You will see the same uncertainty with any programming language. Either switch to LabVIEW real-time or live with the small amount of jitter.
Message 6 of 19
(7,433 Views)
OK.Thanks.
What do u mean :"LABVIEW real time" ? Do  I have to use some of  real time  NI  board ?
Message 7 of 19
(7,427 Views)
Accepted by topic author alex62
No. It's an alternative operating system to Windows.
https://www.ni.com/en-us/shop/product/labview-real-time-module.html
Message 8 of 19
(7,422 Views)
Thanks a lot.
I will think about  real  time LABVIEW module.
Message 9 of 19
(7,416 Views)
For LabVIEW RealTime, you will nee an NI RT controller.  These are most common in cRIO or PXI.  So you may not be able to use the PCI-8431 anymore.  Possibly the PXI version of that card if you use a PXI RT controller.
Message 10 of 19
(7,412 Views)
