NI-PXI 4070 returns -1074126845 on IviDmm.RevisionQuery
i am running the ivi function RevisionQuery on a 4070-DMM but i get the error -1074126845 (Max Time exceeded before operation completed.)
Can i set a timeout value somewhere in NI MAX?
The interesting thing is: I am calling a custom C#-dll that executes this ivi-function. When running under C# then the function returns the revision and no error. But when i call this c#-dll in teststand then it does not work anymore.
Most of the other functions like read / init&fetch are working. So the handle to the device should be ok.
Thx for help and ideas
I am using:
Windows 7 64bit
NI TestStand 2016
NI Max 16
NI DMM 15.2
(3,005 Views)
Accepted by topic author OnlyOne
Solved:
Wrong StationGlobal was used for vi parameter.
(2,975 Views)
