NI-Scope and Digitalizer
The NI-scope driver is for controlling high speed digitalizer.  According to my understanding, a digitalizer is an instrument that convert an analog signal into digital.  Am I correct?  If that's the case, isn't all the analog input module digitalizer, and the NI-scope driver would apply to all analog module?  Does the NI-scope driver apply to a USB-6008?
Kudos and Accepted as Solution are welcome!
(4,263 Views)
No, 6008 uses DAQmx. NI-SCOPE supports hardware in http://www.ni.com/digitizers/.
(4,257 Views)
