NI Spy Time stamp format
I'm Using NI spy. I want to calculate the elapsed time between write and read.
Write 08:50:56.5346
Read 08:50:56.5358
Hour:Mimute:Second
The second portion contains decimal point and 4 digits. What should I consider the fraction? as we know the fraction of a second is the millisecond.
(2,497 Views)
Shamsan,
The decimal refers to the accuracy of the second. In the example you posted below, the Write time is 8 hours, 50 minutes, 56 seconds, and 534.6 milliseconds. The 4th decimal digit marks ten-thousandths of a second.
I hope this helps.
Patrick O.
Applications Engineering
(2,457 Views)
