NI USB-232- not able detect
I am using NI USB-232 (188345C-02) is not able to detect in NI MAX and even in device manager.
Do I need to install any driver to use it?
Best regards
(4,375 Views)
It generally is not going to detect that interface unless it is connected to an instrument.  The only thing that may be present may be an additional COM port.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,333 Views)
I need a definition USB-232   188345c-02
(2,112 Views)
Check control panel, serial port configuration, you will know is it communication available.
(2,068 Views)
