NI-VISA 5.0 GPIB board not detected
I have a long recurring problem with nivisa 5.0 on linux machine w/ kernel 2.6.32-21. I succeeded to compile (see my post http://decibel.ni.com/content/docs/DOC-13584) but the GPIB board is not detected.
First check that all the modules are incorporated in the Kernel
>lsmod | grep ni
>nipalk               1220783  3 NiViPciK
>nikal                  57338  1 nipalk
In python if I try to look up at the instruments through pyvisa
In[1]: import visa
In [2]: visa.get_instruments_list()
Out[2]: ['ASRL1']
Here is the visa version used:
Information from the binary package:
Name        : nivisa                       Relocations: (not relocatable)
Version     : 5.0.0                             Vendor: National Instruments Corporation
Release     : f0                            Build Date: jeu. 24 juin 2010 21:52:54 CEST
Install Date: (not installed)               Build Host: construx.natinst.com
Group       : Applications/Engineering      Source RPM: nivisa-5.0.0-f0.src.rpm
Size        : 8169681                          License: Copyright (c) 2002-2010 National Instruments Corporation. All Rights
On older machine w/ kernel 2.6.15-29
Version     : 4.2.0                             Vendor: National Instruments Corporation
Release     : f1                            Build Date: ven 20 jui 2007 03:19:44 CEST
Group       : Applications/Engineering      Source RPM: nivisa-4.2.0-f1.src.rpm
Size        : 3274924                          License: Copyright (c) 2002-2007 National Ins
truments Corporation. All Rights Reserved.
Signature   : (none)
Packager    : National Instruments Corporation
URL         : http://www.ni.com/linux/
Summary     : NI-VISA Runtime Engine -- Abtraction layer for access to NI-488, PCI/PXI, USB,
 TCP/IP, VXI and Serial resources
Description :
Out[2]: ['GPIB0::8']
(4,011 Views)
(3,993 Views)
Hello mtblanc,
Thank you for posting on NI forums.
To make things a little more clear, which kind of module/hardware do you want to use ?
If it is supported by NI-488.2, you may want to check this out : GPIB on Ubuntu.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(3,973 Views)
It looks to me like you have installed NI-VISA, but you have not installed the NI-488.2 driver. Both are required for GPIB communication through NI-VISA to function.
-Jason S.
(3,957 Views)
Dear Jason,
Yes I know the tutorial -actually I am the author of this tutorial, as well as more recent ones (DOC-13584)-. My problem is with recent version of nivisa(5.0)/ubuntu. It seems that the gpib card is not detected. There seems to be other post about it.
http://decibel.ni.com/content/thread/7491?decorator=print&displayFullThread=true
I was wondering what could be done to check the origin of the problem?
I shall mention that the mentioned conflict with gpib_common (thread above) is not, in my modest opinion, the real source of the problem. It should work and it has worked.
Installed nivisa5.0, kernel 2.6.32-21, gpib-linux 3.2.15
Cheers,
Olivier
(3,936 Views)
For info here is the log file:
(3,932 Views)
