NI-VISA Crashing after Update
Hi All,
I have been using NI-VISA runtime 4.3 for some time now (as it is a dependency for the Ultrascope DS1000 software I use) and recently installed NI-VISA 15.0 found here. After installing the upgrade I get a crash every time i attampt to connect to my instrument as shown below.
This crash is not isolated to that particular program however as I experience the same crashing problem when i attempt to connect to the instrument in my c# code on the connection attempt line below. Has anyone else experienced this problem or have an idea what I can do to fix it? futher more could someone help to explain the difference between NI-VISTA drivers and NI-VISTA runtime Eninge??
 mbSession = (MessageBasedSession)ResourceManager.GetLocalManager().Open(strVISARsrc);
(4,225 Views)
Can you communicate to an instrument in MAX? What sort of connection do you have for the instrument? What is your os? You did a large jump from 4.3. Did you check with the vendor to see whether you need to upgrade the application you are you using?
The runtime does not contain any development tools.
(4,208 Views)
I use Windows 10.
The instrument has a USB connection
Vendor has supplied me with the latest software
Seems to have fixed the issue by completly uninstalling NI-VISA and re-installing
(4,203 Views)
