NI VISA OpenSUSE 12.2
I`m trying to install NI-VISA on my OpenSUSE 12.2 64-bit system. The latest version for Linux, that I found, was NI-VISA 5.1.2. The instalation aborted with the error:
  NI-VISA for Linux
     version 5.1.2f0 for Linux
National Instruments products support the following Linux distributions:
   openSUSE
   Red Hat Enterprise Linux Desktop + Workstation
Refer to README.txt for the latest information at the time of release.
Refer to www.ni.com/linux for the most recent information about Linux
support at National Instruments.
Continue? [Yn] y
Checking required install tools...
Checking installer tool versions...
rpm        4.9.1.2 can be used with a default installation path
tar        1.26
Checking dependencies...
glibc      2.15
Unpacking install files to /tmp/nivisa-5.1.2f0.install...
*********************************** ERROR ************************************
*       ERROR: 3.4 kernels are not supported!          *
*    Running a 2.6.x kernel is required to continue this installation.       *
Installer is aborted.
Is there a version for SUSE 12.2 available, or some other way so that I can install NI-VISA?
Thank you for help,
Stefan
(4,604 Views)
According to http://download.ni.com/support/softlib//visa/NI-VISA/5.1.2/linux/README.txt
you need OpenSuse 11.3 32-bit version
(4,597 Views)
Ok, I can see that, but is there no version for my system?
(4,594 Views)
Not according to NI.com
NI-VISA 5.2 is Windows-only right now.
(4,590 Views)
There's a non official way for installing NI-VISA 5.2 on opensuse 11.3 and 12.1.
Just get the last version of DAQMx for linux.
Regards.
(4,487 Views)
I would suggest installing NI-VISA 5.3. It does not list support for OpenSUSE 12.2, just 12.1, but it is much more likely to work than anything older.
(4,448 Views)
NI VISA 5.4 is supported in OpenSUSE 12.2:
http://joule.ni.com/nidu/cds/view/p/id/4234/lang/en
Mason M
(4,235 Views)
