NI_VISA USB RAW Mode for Window 10
Following the instruction below to config my instrument to "USB RAW Mode" , it does not seems to work on Windows 10 machine.
I was able to have the process working on Windows 7 Machine both 32 bit and 64 bit.
Any tricks?
Shu
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
(3,936 Views)
Hi sj1993,
Which version of the VISA drivers are you using? Also, what behavior are you seeing that seems like it's not working?
Cheers,
Ryan
(3,889 Views)
Ryan,
I have tried a few different rev of Visa driver - including the latest on NI web
What works, the device shows up as USB device and on NI max.  When not working, device not appear on NI-Max
SJ
(3,857 Views)
Hi SJ,
If you're seeing the device disconnecting randomly, try using a different USB port. It's especially useful to use the USB ports on the back of your PC if you're using a desktop. It also might be useful to use a powered USB hub to maintain your connection. This article gives some more information about the subject:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MucSAE&l=en-US
Cheers,
Ryan
(3,837 Views)
