NI-VISA & Delphi
Hello!
I work with programmable power supply P9610A. I use NI-VISA 18 software and drivers. I wrote this code:
function viOpenDefaultRM(rm: PInteger)
                             : Integer; stdcall; external 'visa32.dll';
function viFindRsrc(RM: Integer; Res: PChar; PfindList, PnumInstrs:
   PInteger; Resource: PChar): Integer; stdcall; external 'visa32.dll';
function viOpen(RM: Integer; ResourceName: pChar; AccessMode,TimeOut:
       Integer; vi: PInteger): Integer; stdcall; external 'visa32.dll';
procedure TForm1.Button1Click(Sender: TObject);
 var Resource: array[0..255]of Widechar;
     Status: integer;
     SerN_: PWideChar;
     ResourceName : PWideChar;
begin
  viOpenDefaultRM(@RM);
  SerN_:= PChar('?*'+LabeledEdit1.Text+'?*');
  Status:= viFindRsrc(RM, SerN_, @findList, @numInstrs, Resource);
  Status:= viOpen(RM, Resource, 0, 0, @AKIP);
end;
It doesn't work, although in Visa Test Panel all commands are successful. I start NI I/O Trace and found this:
In Visa Test Panel
9.  viOpenDefaultRM (0x00732748)
Process ID: 0x00001450         Thread ID: 0x0000140C
Start Time: 11:23:16,8840      Call Duration 00:00:00.0190
Status: 0 (VI_SUCCESS)
10.  viParseRsrc (0x00732748, "USB0::0x164E::0x0FB2::TW00027923::INSTR", 7 (0x7), 0 (0x0))
Start Time: 11:23:16,9030      Call Duration 00:00:00.0000
in my program
3.  viOpenDefaultRM (0x0075C3A8)
Process ID: 0x000007F8         Thread ID: 0x00000304
Start Time: 11:22:40,5149      Call Duration 00:00:00.1980
> 4.  viFindRsrc (0x0075C3A8, "?", 0x00000000, 0 (0x0), "")
> Start Time: 11:22:42,7131      Call Duration 00:00:00.3510
> Status: 0xBFFF0011 (VI_ERROR_RSRC_NFOUND)
I.e. in function viFindRsrc only the first character is sent. What is the reason?
(4,369 Views)
PChar is PWideChar.
But visa32.dll need PAnsiChar.
So, try to exchange from 'PChar' to 'PAnsiChar'.
(3,065 Views)
