NI VISA and Arduino interface
We are facing issues when transferring Integer values from Labview to Arduino via VISA over a serial interface. The values being sent are real-time. How to read values simultaneously in the arduino code.
(2,961 Views)
Make sure that a parallel loop, or interupt routine reads the data each so many milliseconds.
What problems do you have?
Are you sure you have a main loop that checks the serial port regularly?
greetings from the Netherlands
(2,946 Views)
In addition, what is the format of the data you are sending?  You need to make sure you are using the same format on the Arduino side.  If you can share some code, that would help us help you.
(2,914 Views)
