NI VISA freezes when initializing
Why does NI VIsa configuration (version 5.3) freezes in initializing?
Message 1 of 15
(7,472 Views)
Hi Spoudel,
Is that a fresh install? Or it had been working before?
Also, which OS are you using?
Carmen C.
Message 2 of 15
(7,438 Views)
Are you able to open VISA Interactive Control or use any other VISA functionality (in LabVIEW or MAX, for example?)
Message 3 of 15
(7,431 Views)
Its a fresh install in Mac OSX 10.8. I tried 5.1.2, and 5.3. None of them work!
Message 4 of 15
(7,411 Views)
That's definitely a major inconvenience. Do you have LabVIEW or any NI drivers installed on the machine aside from VISA? If so, could you provide the version information, please?
Message 5 of 15
(7,402 Views)
Well, I have Labview 2010, but no other visa drivers. I am trying to link my arduino to Labview, hence NI VISA.
Message 6 of 15
(7,393 Views)
I see... What about 488.2/GPIB? I've seen this before with older versions of this driver. If it was installed, there would likely be an Applications/National Instruments/NI-488.2 directory.
Message 7 of 15
(7,390 Views)
Hi, were you able to solve this issue? I also got Arduino Uno and have exactly the same problem. NI-Visa freezes while initializing...
I am using Labview 32-bit 2011 on Mac OSX 10.8.4.
Let me know if you could make it work. I'm dying to get started with my Arduino!
Thanks in advance.
Message 8 of 15
(7,308 Views)
I just installed VISA 5.4 on my Mac (OS X 10.8.4, 27" iMac) and NI-VISA Configuration.app runs without any problems.   I have had several earlier versions of VISA and multiple versions of LV on this computer.
Lynn
Message 9 of 15
(7,296 Views)
Thanks for the response Lynn. I have the same version of NI-Visa and OSX on a macbook pro. But still NI-Visa freezes on the initializing window.
Can you let me know if you are booting with 32-bit or 64-bit kernel?
Message 10 of 15
(7,283 Views)
