NI Visa TCPIP Clear method
I am communicating with a Chroma 19036 via NI Visa V19.0 ( TCPIP /message based session ). I need to be able to clear the response buffer as a result of say, issuing multiple writes which generate a device response without a read between them, etc. I received method not supported error when using the session.clear() method and normal IOProtocol. I have tried changing the session IOProtocol to Ieee4882 and received the same error. The documentation seems to indicate that the clear method is in fact supported. Can anyone provide any guidance/help. Thank you in advance,
Ray.
Message 1 of 1
(2,316 Views)
