NI4065 which DLL's required for ansi C program ?
Hi all,
the product I am using is the NI 4065 DMM with USB bus. I have written an application in C which controls the DMM via the USB bus. The sources include the "nidmm.h" header and require the the nidmm_32.dll on a Win7 system.
I have installed the required headers and DLL's using the NI302 installer, basically installing the complete software.
When trying to deploy the program on another PC, I could not find out which DLL's from the NI installation to deploy with the program. Obviously deploying only the nidmm_32.dll does not suffice.
Which DLL's do I need ?
Thanks and best regars,
Jan
(3,000 Views)
Hi Jan,
I am not sure if I understood your question correctly, but to me it seems, that you didnt install the NI-DMM driver on the other PC. Have you done that? If you dont install the driver, it will not work.
I have never heard about NI302, so I dont know, what that is.
I hope this helps, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,991 Views)
