NI488.2 (gpib-usb-b) linux install. ERROR : gcc does not appear to be installed!
I'm trying to install the driver for GPIB-USB-B (ni488.2) for linux (ubuntu). I have downloaded the driver and run the script "INSTALL". Unfortunately, I get the error message :
Installation of gcc is required to continue this installation.
I don't understand because gcc is already installed. In compile c files easily.
Any help pointing out my error would be appreciated.
Paul
(3,478 Views)
Hello Paul,
Ubuntu is not officially supported by National Instruments. So it is difficult to find a solution for your issue.
Did you read these documents?
http://decibel.ni.com/content/docs/DOC-4140
http://www.ni.com/pdf/manuals/371334c.pdf
Regards
Jean-Philippe C.
National Instruments France
(3,459 Views)
