NI488 V2.3 driver on Suse Linux 9.3 Kernel 2.6.11.4
Hi everybody,
for long time I worked with Kernel 2.4 and NI488 v0.89 with no problems.
For some reason (out of this scope) I had to switch to Suse 9.3, Kernel 2.6.11.4 and therefor NI488 V2.3
for my PCI GPIB.
The driver could not be compiled and installed!
The solution is simple: Function usb_epnum_to_ep_desc in /usr/src/linux/drivers/usb/core/usb.c
does no more exist. I solved this problem by editing ../natinst/nikal/src/nikal.c at two positions:
// cfsw 20050530 replace next line with following line
//endpointDesc = usb_epnum_to_ep_desc(usbDevice, kalURB->endpoint);
endpointDesc = usbDevice->ep_in[kalURB->endpoint];
now the driver compiles without errors and works fine.
My main problem was to get through the installation scripts AND include this correction, which
results in quite a lot of shell commands.
As far as I know any kernel with version number > 2.6.8 will lead to this problem.
I hope this hint will help others to save time and encourage more users to work with
Linux and NI GPIB, which is an excellent solution.
have fun
cfsw
(3,674 Views)
further issues with Kernel 2.6.11
1) I saw this posted elsewhere, in nikal.c line 196:
// 20050728 cfm I moved the definitions for the following inlined functions here
// now the file compiles ...
static inline nNIKAL100_tBoolean nNIKAL100_isKernelContiguousPointer(const void *ptr)
   return ((nNIKAL100_tUPtr)ptr < (unsigned)VMALLOC_START);
static inline nNIKAL100_tBoolean nNIKAL100_isKernelVirtualPointer(const void *ptr)
   return ((((nNIKAL100_tUPtr)ptr >= (unsigned)VMALLOC_START) &&
      ((nNIKAL100_tUPtr)ptr < (unsigned)VMALLOC_END)));
2) the function / symbol remap_page_range was not found.
The command:
>>grep remap_page_range /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/*/*
/usr/src/kernels/2.6.11-1.1369_FC4-i686/include/asm/pgtable.h:#define io_remap_page_range(vma, vaddr, paddr, size, prot)
A look at pgtable.h finds:
#define io_remap_page_range(vma, vaddr, paddr, size, prot)        \
        remap_pfn_range(vma, vaddr, (paddr) >> PAGE_SHIFT, size, prot)
#define io_remap_pfn_range(vma, vaddr, pfn, size, prot)        \
# grep "define PAGE_SHIFT" /usr/src/kernels/2.6.11-1.1369_FC4-i686/include/*/*
/usr/src/kernels/2.6.11-1.1369_FC4-i686/include/asm/page.h:#define PAGE_SHIFT   12
included....
on line 1245 of nikal.c change the following:
   status =
//#ifdef nNIKAL100_kFiveParameterRemapPageRange
   remap_pfn_range(vma,vma->vm_start, physAddr,
                    (vma->vm_end - vma->vm_start)>>12,
                    vma->vm_page_prot);
//   remap_page_range(vma, vma->vm_start, physAddr,
//                    (vma->vm_end - vma->vm_start),
//                    vma->vm_page_prot);
//#else
   remap_page_range(vma->vm_start, physAddr,
                    vma->vm_page_prot);
//#endif
and still I have not got it all because the test utility gpibtsw gives me:
____
The NI-488.2 Software is not correctly installed on your system.  Please follow these steps:
1. Restart your system.
2. Reinstall the NI488.2 Software.
3.  Run the Troubleshooting Wizard again.
[OK]
____
This is what the system log tells me about the boot up process and these drivers.....
I dont know what more to do with it...... any help out there?
Jul 30 13:12:40 desk kernel: nikal: module license 'Copyright (c).....' taints kernel.
Jul 30 13:12:40 desk nipalsm: [libnipalu.so.1.9]  Warning: source/lib/linux/linLoadKern.cpp:168 - libKernelDriverLoad: Failed to open nipalk, errno: 2
Jul 30 13:12:40 desk nipalsm: [libnipalu.so.1.9]  Warning: source/initcln/initcln.cpp:147 - Posix: Init kInitClnPackage: kernelDriver: failed! status=-50204
Jul 30 13:12:40 desk nipalsm: [libnipalu.so.1.9]  Warning: source/package/posix/ulibEntry.cpp:192 - initialize: unable to load NI-PAL. status=-50204
Jul 30 13:12:40 desk kernel: nipalk: no version for "nNIKAL100_getTimeOfDayInterval" found: kernel tainted.
I've checked the function "nNIKAL100_getTimeOfDayInterval" and it is present in nikal.c and exported...????
any one got a clue.... I sure need one I think it may have something to do with the NI-VISA but not sure.....
.chuck
(3,576 Views)
