NI6343 resistor measurement
May NI6343 board measure  the resistor(about 10KOhm )  ?
Is there a channel which can measure the resistor absolutly and directly ?
Or I should use a AO channel to provide a stable voltage, then use a stable(with temperature) resistor to connect with the resistor  to be measured, and another AI channel to get the voltage ?
If it's able,  how?
And what's the precision?
Thank you
(4,356 Views)
I'd like to measure the resistor change with temperature.
So what's the steability of the AO channel against temperature change.
(4,355 Views)
