NIDAQmx .NET library - missing function
I am planning to use the NIDAQmx .NET library to control the devices in my PXI chassis over TestStand.
I add a .NET step and use the DLL that I downloaded from the NI website.
However, some functions are missing, like SetAnalogPowerUpStates. Is this function exluded deliberately because of its variable parameter count?
Before the .NET module I tried to use the ANSI C library, NIDAQmx.lib. That function appears with the name "SetAnalogPowerUpStates_VB6" and when the step calls this function, a run-time error occurs with error code -17502.
So, it looks like there is no direct way of calling this function from TestStand?
Any comments?
S. Eren BALCI
IMESTEK
(3,534 Views)
Wrong Forum
Please use another forum for this question.
use Multifunction DAQ instead of GPIBSerial, VISA
You have a much better chance to get a good answer there
greetings from the Netherlands
(3,533 Views)
This topic has been moved to the Multifunction DAQ forums here.
Matt Anderson
Hardware Services Marketing Manager
(3,511 Views)
