NIDmm .net Version number update?
After updating NI-Dmm to version 15.1, I was expecting the NationalInstruments.ModularInstruments.NIDmm.dll version numbers to get update to 15.1.x as well, but the only dlls found in Program Files (x86) are 1.0.40.152, and the description says ".NET API for NI-DMM 1.0".
Is version 1.0.40.152 is the latest .NET NI-Dmm dll?  If not , where does it get installed to?  It's clearly not under Program Files (x86).
(3,991 Views)
Hi Curtis, what's the directory you're looking in to find that DLL? I can't find it on my machine.
(3,969 Views)
On my Windows 10 machine, it was found under
C:\Program Files (x86)\IVI Foundation\IVI\Microsoft.NET\Framework32\v4.0.30319\NationalInstruments.ModularInstruments.NIDmm 1.0
(3,967 Views)
Ah, so I beileve the confusion may be between NI-DMM and IVI DMM Compliance.
NI-DMM is specifically for National Instrument's modular DMM prodcuts.
IVI DMM is a standard many DMMs meet. National Instruments makes and supports IVI compliant drivers. I am linking this and some related information below.
NI Drivers Results
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/n8:3,ssnav:ndr/sb/-nigenso4-...
What is IVI?
https://www.ni.com/ivi/what.htm
(3,957 Views)
