NIKAL1.9, NI 488.2, NI-VISA on CentOS 5.3 32 Bits
Hi All,
I'm trying to install NI-488.2 and NI-VISA on a fresh CentOS 5.3 32 Bits x386 system.
Kernel: uname -r gives  2.6.18-128.el5
I did install the kernel headers with
yum install kernel-devel
Unfortunately during instalation, sh ./INSTALL,  I get the error message
 ******************************** ERROR ****************************************
* Kernel source in /lib/modules/2.6.18-128.el5/source does not appear to be
* for the 2.6.18-128.el5 kernel.
* Ensure that kernel source for the 2.6.18-128.el5 kernel is installed
* and configured.  Refer to the README file for the product you are           *
* installing for information about configuring your kernel source.            *
Does anybody know a solution for this issue?
Best regards and thank you in advance
peter
(5,382 Views)
Hi Peter,
here's a list of supported operating systems for the GPIB driver: GPIB Driver Versions
You could try and re-install the kernel sources entirely. This centos page describes how.
Searching the forums lead me to the following entry: NI-488.2 install error Kernel source problem
This thread refers to other threads containing information and patches for the NI-KAL.
I am a Windows / Mac OS user myself, so hopefully we'll get some additional information from Linux users in this forum.
Peter
Peter A.
Field Sales Engineer, NI Germany
(5,343 Views)
Hi Peter,
thank you for your response.
I did try
cd /usr/src/kernels/2.6.18-128.1.6.el5-i686/include/linux
mv version.h version.h.orig
cat utsrelease.h version.h.orig > version.h
ln -s /usr/src/kernels/2.6.18-128.1.6.el5-i686/include/asm/asm-offsets.h /usr/src/kernels/2.6.18-128.1.6.el5-i686/include/asm/asm_offsets.h
as suggested in
http://forums.ni.com/ni/board/message?board.id=250&thread.id=27554&view=by_date_ascending&page=3
This is my version .h
#define UTS_RELEASE "2.6.18-128.1.6.el5"
#define LINUX_VERSION_CODE 132626
#define KERNEL_VERSION(a,b,c) (((a) << 16) + ((b) << 8) + (c))
#define RHEL_MAJOR 5
#define RHEL_MINOR 3
#define RHEL_RELEASE_CODE 1283
#define RHEL_RELEASE_VERSION(a,b) (((a) << 8) + (b))
But I still have the avard winning stupid error message
What is really tested here?
Best regards and thank you in advance peter
(5,335 Views)
muellerp wrote:
I did try
as suggested in
This isn't needed as long as you are using the latest version of NI-KAL (currently 1.9).  From the subject of this post it looks like you are using the latest version so you should be fine.
Of course looking at the path you provided to your kernel source probably shows the answer to your problem.   "2.6.18-128.1.6.el5-i686" is probably not the kernel source for "2.6.18-128.el5"
All of these checks come from NI-KAL, and NI-KAL 1.9 does the following to trigger this error:
   # check that the headers dir that we found is for the correct version of
   # the kernel
   sourceVersionStatus=$statusSuccess
   if [ "`$GREP UTS_RELEASE $headersDir/include/linux/version.h | $GREP -c \"$kernelVersion\"`" = "0" ]; then
      if [ -e $headersDir/include/linux/utsrelease.h ]; then
         if [ "`$GREP UTS_RELEASE $headersDir/include/linux/utsrelease.h | $GREP -c \"$kernelVersion\"`" = "0" ]; then
            sourceVersionStatus=$statusFail
         fi
      else
      fi
   fi
As you can see from what you posted in your version.h "2.6.18-128.1.6.el5" is not the same thing as "2.6.18-128.el5" so we fail.  I would just run:
yum update kernel
yum update kernel-devel
# double check that you have matching kernel and kernel-devel versions
rpm -qa | grep ^kernel
reboot
Then try the installer again.
Shawn Bohrer
Use NI products on Linux? Come join the NI Linux Users Community
(5,321 Views)
Hi Shawn,
many thanks for your help. Updating the system did help. (There was no indication at CentOS that there are software updates available. So I did this manually with the 'software updater'. )
Than I installed in the following order:
NIKAL 1.9
NI-488.2-beta-2.5.1b1
NI-VISA-4.5.0
Thanks again. As of today
CentOS 5.3, x86 32Bit system, this is doing the job.
Best regards peter
(5,314 Views)
