NIMAX connection with GPIB-USB-HS
I am attempting to try and communicate with a Newport Conerstone Monochromator (manual) through a GPIB-USB-HS USB to GBIB controller. I have used the GPIB-USB-HS controller with a SR860 lock-in amplifier and it works fine.
When I connect the GPIB-USB-HS to the monochromator the NI-MAX registers an instrument and it shows the Primary Address as 4 (which is the default according to page 57 of manual) but it doesn't find the model or the status. I also get the instrument did not respond to the *IDN? command error. This may not be unexpected as the device may not respond to this as page 57 in the manual lists a INFO? command which mimicks the IDN command.
Using the NI-488.2 Communicator and trying to send the command "INFO?[lf]" (or "INFO? [cr][lf]"). I get a timeout error, in both the write and read function. Same thing happens if I try to communicate using the VISA test pannel.
Included with the monochromator is a software known as monoterm. I am unable to connect to this program through the GPIB-USB-HS either.
I have tried uninstalling and reinstalling all the associated software to no avail. If anyone has any experience with these devices or has any suggestions I would appreciate it.
Cheers, Drew.
(3,389 Views)
Hi!
Are you getting an error in MAX at all?
What driver are you using for your GPIB controller?
I recommend looking at this Knowledge Base article if you're having trouble communicating with your device.
Cheers!
Jacob Hopkins
Technical Support Engineer
(3,351 Views)
Hi Drew,
You're correct that instrument doesn't support the standard IEEE 488.2 commands like *IDN?.  It only supports a limited set of specific commands listed.  Can you try sending the querry..
INFO?\r\n
Note the termination characters are ([cr] = \r and [lf] = \n).
Craig
(3,341 Views)
