NTN4882
I'm using TLCINT and STOP Interrupts.
When TLCINT interrupt occurs I read the Data from FIFOB and reply by putting the data on FIFOB, then GO command.
Sometimes TLCINT interrupt occurs and when I read FIFOB I find the same data I put before.
How can I resolve this conflict?
Thanks.
(3,895 Views)
TLCINT is just the logical OR of ISRs 1, 2, and 3. Do you know what specific interrupt bit is setting in ISR1, 2, or 3 that causes TLCINT to assert?
Also, you need to do some other configuration when switching from receiving to transmitting before writing the GO command.
Can you correlate the failure you are seeing with any error at the host? Are you using NI-488 software for the host?
When you are reading the FIFOs, how do you determine if there is valid data in the FIFOs and how many bytes you should read?
Sorry for the rambling answer but your initial post didn't give me much detail about your problem.
(3,891 Views)
(3,890 Views)
Thank you Collin,
This is what I did:
I knew that TLCINT is an ored interrupts from ISR1 where I'm using RXEND.
Prepare Chip for RX Data from GPIB by:
CFG=0x28
CNT1=0xFF
CNT0=0xF0
CMDR=0x04
when INT occurs, TLCINT , I do :
nBytes= CNT0
nBytes= nBytes-0xF0
Read nBytes from FIFOB
then perform again the above blue statements.
When I reply, I do:
CFG=0x08
N= 2's comp of Num bytes reply
CMDR=0x10
CNT1= 0XFF
CNT0=N
Write Num to FIFOB.
CMDR = 0x04
When STOP Interrupt occurs, I write the above blue statements.
I'm looking for a way to stop interrupt while reply not yet dispatched over GPIB from FIFOB.
Because any coming Interrupt would make me read FIFOB, which is the dispatched data, i.e data I have put in FIFOB.
(3,891 Views)
I posted this yesterday and it may help you....http://forums.ni.com/ni/board/message?board.id=140&message.id=19803
Message Edited by GPIB Guru on 10-20-2006 07:14 AM
Message Edited by GPIB Guru on 10-20-2006 07:15 AM
(3,880 Views)
