Need better understanding different buses
Hi All,
I'm trying find some good resource on internet to better understand different buses. Viz.,
  • VISA
  • GPIB
  • Serial
  • Ethernet
  • PCI
  • PXI
  • VXI
  • IVI
  • Modbus
  • Profibus etc.., (generally all communication buses and protocols)
Whenever I work in some communication (say Serial or GPIB), I get through it using VISA functions in LabVIEW and with little knowledge about the actual bus.  But what I want to know is how such communication buses are different from each other.  Some brief about each buses.  Some sources on internet which explains them without getting too detail explanation.  A book suggestion will also be an appreciable.
Ajay
Ajay MV
(4,009 Views)
Wikipedia always comes through for me.  And VISA is not a communication bus.  It is an abstraction layer so you don't need to know the low level driver stuff.
(4,003 Views)
jjp377,
They are very good links.  I still look for some details on Modbus, Profibus, Fieldbus..
--Ajay
Ajay MV
(3,925 Views)
Modbus has a website that has the specs and explanations of most of what you want: http://modbus.org/tech.php
The Profibus website is also helpful: http://www.profibus.com/downloads/
However, if you want access to the low level specifications you need to buy them.
Your list is missing the CIP protocols, maintained by odiva: http://www.odva.org/Home/tabid/53/lng/en-US/Default.aspx
Jesse Dennis
Engineer
INTP
(3,919 Views)
