Need help on ITC503
I am trying to connect ITC503 �Intelligent???� controller.
It is expecting an End-of-String (EOS) character, and the carriage-return is the EOS character. I don�t have any manual, but I am pretty sure that I have set correct correctly set the EOS character to carriage return in the GPIB ibdev function, or at list I made a lot of efforts to initialise correctly the GPIB interface. Any way I cannot connect at all to device, and when I use the LabView drivers Its works without problems. But I need to use LabWindows instead the LV. I need a code on ibdev function to correctly initialse the GPIB interface. It seems that the ITC503 is not a standard GPIB device. I am seriously in doubt whether the ITC should really called, and not only TC! L
Please
Help!
Best Regards
Nikolai
(4,135 Views)
Hello Nikolai,
See Introduction to the Interactive Control (IBIC)  for the basic communication commands, then for more detail(including the answer to your question), see NI-488.2 Function Reference Manual for Windows
(Look up ibdev and ibeos.)
Ray K
NI Applications Engineer
Message Edited by Support on 02-23-2009 04:34 PM
(4,135 Views)
Hi Ray,
Thanks!
I should really learn to read before complain :-)!
The problem was that I set correctly the EOS character but newer think about that I have to added at the end of every command.
Best Regards,
Nikolai
(4,135 Views)
