Need help on USB-8452 Error -301743
When i execute the I2C write program, The error displayed "Error -301743 occurred at NI-845x I2C Write.vi:4470001" .How can i rectify it?
(3,688 Views)
I don't have LabVIEW in front of me.  Go to Help->Explain Error and then put in your error code.  What description do you get?
(3,663 Views)
In Labview, the explain error shows that
error 301743 occurred at an unidentified location
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (301743) or for its hexadecimal representation (0x00049AAF).
(3,660 Views)
First of all, your error code is negative.  That is important.
Now that I am at my desk, I can see that error code -301743 means that the device you are trying to talk to did not return an ACK.  My first thought is that you are using the wrong address.
(3,654 Views)
