Need more info for viClear error code VI_ERROR_INV_SETUP
I am getting a VI_ERROR_INV_SETUP error code in response to a VISA viClear function on a COM port.  Other than that, everything seems to run OK.  This is a new instrument installation so I suspect it is a configuration issue.  However, the description for VI_ERROR_INV_SETUP error code, "Unable to start operation because setup is invalid (due to attributes being set to an inconsisntent state)." does not give me a clue which attribute is at fault.  Anybody have an inight into this?  Thanks.
(3,865 Views)
I think you need to set the VI_ATTR_IO_PROT attribute to VI_PROT_4882_STRS. The viClear wants to send a *cls to a SCPI based instrument and you need to set this attribute for it to work.
(3,857 Views)
Serial's viClear() behaviour has changed from VISA spec 3.0 a bit.  It now performs Send Break and does not require VI_ATTR_4882_STRS being set.  You should upgrade to the latest NI-VISA version.
(3,843 Views)
I did set the VI_ATTR_IO_PROT per cymrieg's suggestion and it did fix the problem.  I am running VISA 2.6.1 and will try the VISA update per Makoto's suggestion as an alternative.  Thanks for your prompt and helpful reply.
(3,831 Views)
