Need some help controlling Ruska 7000 through Labview
I wanted to control a Ruska Series 7000 Digital Pressure Controller (7010-705N) by sending a recipe of different set point and durations through labview. The ruska has a GPIB port. I have a GPIB  USB HS cable. My questions are :
(1) Could anyone direct me to the right driver page ? The only drivers that I found on NI are for 7250, 7252, and 7615. I am not sure if it would support this older model
(2) Could anyone share some suggestions on how to design the LV part ? I wanted to send a recipe, for example 5 PSI for 5 min, 30 PSI for 10 min etc. If anyone can share a generic VI template for me to start off That would be awesome.
Many many thanks
LabView Newbie
(4,806 Views)
You'll have to compare the commands in your manual to what is in the driver for the newer model and make the appropriate changes.
(4,789 Views)
