The golden rule in serial (UART) communication, is that if two communicating partners are within +-2% of each other, they'll happily communicate error-free. Since you often only know one side of the equation, the window narrows to +-1%.
Next, take a look at how baud rates are calculated. On most NI-Serial hardware, there is a 7.3728 MHz oscillator that is divided by 16 (to create the what I'll call the 'base' frequency), and then divided again by a divisor latch. A divisor latch value of 1 yields 460800, 2 = 230400, 3 = 153600, etc. This is where the 'standard' baud rates come from.
However, on some OS's, we divide the clock source again by 4 before it hits the divisor latch. This means 1 = 115200, 2 = 57600, etc. While this does creat
e a set of 'standard' baud rates, it also limits the number of possible baud rates. This is something that will be fixed in the future.
Now hopefully the following table will make sense. In systems that have a base of 460800, we support baud rates that are within +-1% of the following (baudrates marked with * are supported in 115200 base systems):
110-9216*, 9404, 9600*, 9804, 10017, 10240, 10472*, 10716, 10971, 11239, 11520*, 11815, 12126, 12454, 12800*, 13165, 13552, 13963, 14400*, 14864, 15360, 15889, 16457*, 17066, 17723, 18432, 19200*, 20034, 20945, 21942, 23040*, 24252, 25600, 27105, 28800*, 30720, 32914, 35446, 38400*, 41890, 46080, 51200, 57600*, 65828, 76800, 92160, 115200*, 153600, 230400, 460800.
10.4k is supported in both systems at the baud rate 10472.
If you're running at 62.5k when set to 57.6k, then you're likely using a 8 Mhz Oscillator. In this case, you have a base of 500000, and with a divisor latch value of 48 you'll be running at 10416. This cor
responds to a 'normal' baud rate setting of 9600. So if you set your modified card to 9600, you should get 10.416k.
