Need vi for Metrohm 718 Stat Titrino
Does anyone have a vi for Metrohm products? The Stat Titrino 718 I'm using interfaces through a serial port.
Thanks a bunch,
Luis
Luis G. Cascão Pereira, Ph.D.
Scientist I
Genencor International
925 Page Mill Road
Palo Alto, CA 94304-1013
Tel: 650-846-7685
Fax: 650-621-8186
Mailto:Lcascao@genencor.com
(3,570 Views)
Hi Luis,
Unfortunately, I was unable to locate a driver for your instrument. I would like you to submit a request for this driver at: http://zone.ni.com/idnet97.nsf/instrumentdriverrequest/ and with the instrument manufacturer. We develop drivers based on demand and popularity so the more requests we have for it, the greater the possibility that we will develop one.
If you would like to try developing your own instrument driver (or modify the existing one), we have documentation, model instrument drivers, and driver templates to help at :
http://www.ni.com/devzone/idnet/development.htm
We also have a syndicate of third party vendors that specialize in National Instruments' products and services. Some of the vendors specialize in driver development.
I would suggest contacting one of the Alliance members at:
http://www.ni.com/alliance
An instrument driver is a collection of functions that implement the commands necessary to perform the instrument�s operations. In short, someone read the instrument user manual and implemented some of the functionality in a program for the end user. Instrument drivers are not necessary to use your instrument. They are merely time savers to help you develop your project so you do not need to study the manual before writing a program.
There are example VI's in LV on Instrument Connectivity. If you go to the Help menu >> Examples.. >> I/O, you will see a couple and Examples.. >> Fundamentals for File and String manipulation. I would suggest tweaking them to suit your application. Also the specific command that your instrument responds to can be found from it's manual.
Some useful resources for your application are
ni.com > NI Developer Zone > Development Library > Instrument Connectivi
ty
http://search.ni.com/?col=alldocs&layout=TechResources&ql=a , to search examples and knowledge bases
Hope this helps!
Best Regards,
Aaron K.
Application Engineer
(3,570 Views)
