New GPIB-USB-HS interface has intermittent Code 6, 'GPIB Send' errors where older GPIB-USB worked fine
I am using LabView 8.6 on a PC running Windows XP.  I have a series of LabView VI's that I have used for years with a borrowed (older) GPIB-USB interface connecting to my instruments.  I recently gave the older interface back to my friend and purchased a GPIB-USB-HS (the only option from NI).  Today I tried to run one of the programs, which talks to a few instruments, in particular a Keithley 238 SMU, on which it slowly increases the current value while taking a measurement on another instrument.  The program sets a value from 0, increasing by 1mA steps up to 200mA - it has always worked fine before.  Now, it runs for a while (varies from e.g. 6 to 54 steps) and then has an error (Code 6, GPIB Send) and gets tied up at that point.  I tried the VI that just sends the current value to the Keithley 238, and it does the same thing - I can run it multiple times but eventually it times out with the same error (code 6).
I have tried removing instruments and GPIB cabling, restarted muliple times etc, to no avail.  I wonder if there is an issue with the interface trying to run in high-speed mode? - the data sheet mentions a HS mode with noninterlocked handshake, could this be the problem, and how would I turn off the high speed mode if it is?  What else could be the issue - short of a bad GPIB-USB-HS interface?
thanks, Paul
Photon999
Message 1 of 9
(5,059 Views)
In MAX, you have the option to change the bus timing. You could try the slowest setting. Sometimes this is necessary for older instruments.
Message 2 of 9
(5,042 Views)
I tried modifying the advanced settings yesterday, setting Bus Timing to 2microseconds (slowest), also I played with the HS488 cable length, tried it off or 15meters.  I just repeated the test with Bus Timing 2us, HS488 cable length off.  I get the same problem, works for a while and then I get the code 6, GPIB send error which ties up the VI.
I am running an older version of NI-488-2 (version 2.5.2), which says it supports the USB-GPIB-HS interface (in Read Me file).  I have the newer version disk (version 2.7.3) that came with the interface - is there any reason that this should work better?  (I prefer to change as little as possible when things are all working...)
thanks
Photon999
Message 3 of 9
(5,039 Views)
OK, I updated NI-488-2 to version 2.7.3, still the same problem.  I also tried the interface plugged into an external USB hub rather than directly into the computer, again, no difference.  Is there something else I can try or change?
Photon999
Message 4 of 9
(5,029 Views)
this device uses the max power, so it is good that you tested with external power.
Also the bustiming on 2Us is OK.
I would also switch off automatic polling (parallel is probably switched off, do it also for serial polling)
How long does it take before the system fails?
greetings from the Netherlands
Message 5 of 9
(5,024 Views)
OK, I switched off automatic polling and it behaves the same.  It takes a different (random) number of times running the routine to send a value to the Keithley 238 SMU, sometimes one of the first values, sometimes over one hundred values are sent before it goes wrong.  With the old (GPIB-USB) interface I never once saw this problem.
Photon999
Message 6 of 9
(5,020 Views)
I have no further ideas, except that the 238 is very old and maybe you are too fast, soemtimes, How fast are you communicating?
I mean incrementing in how many ms?
Message 7 of 9
(4,999 Views)
I am only incrementing every 3 or 4 seconds - that should not seem to be an issue.
Photon999
Message 8 of 9
(4,998 Views)
I agree
Message 9 of 9
(4,996 Views)
