Next button
Does anyone has an example vi for me where with a nextbutton a table is filled with data that  needs to be filled by hand, one value at the time. So what I need is a way to fill a table with data that later on is used to send to a callibrator. I,m using LabView 8.5.
Thanx,
(3,802 Views)
To be more precise I'm using Labview 8.5 the basic version, so I can't use event structures.
(3,798 Views)
Please explain what a nextbutton table is.
And why you think that you need an event structure.
PS this doe belong in the LabVIEW thread not in the instrument thread.
greetings from the Netherlands
(3,780 Views)
