No devices available when creating new switch executive virtual device....
Hi all,
I have a problem creating new switch executive virtual device....
The second screen in the 'create new...' wizard (started from within MAX) has no items listed in the available switches list box, so I cant progress and create the virtual device.
I am using a PXI chassis with a PXI-2565 switch device with the driver installed on the connected PC.  The instrument appears in the devices and interfaces section of MAX under Daqmx devices and I can drive the switches with the Daqmx test panel.
Any ideas anyone?
Cheers
Barry
(3,160 Views)
Hi Barry,
  this is a duplicate of another posting you made in another forum, so we'll try to answer it there.
http://forums.ni.com/ni/board/message?board.id=270&message.id=2007
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,150 Views)
