Not able to separate the serial data
I am trying to make a simple serial read vi but facing a problem that all the data serially coming are not getting separated and getting the plot on the same graph. I m using comma delimiter still not able to separate the data.
The format of coming data :-
Serial.println("95336");
delay(1000);
Serial.println("36.2");
delay(1000);
Serial.println("526.23");
delay(1000);
so on .
I have added the screenshot of my VI
please help me out
(3,595 Views)
Accepted by topic author vibhork10
You are using Println which separates your date with linefeed characters.  Your LabVIEW code is expecting a comma separator.
You need to either do 3 VISA Reads in LabVIEW, or better yet, do a single Println in your C code with the data separated by commas.
(3,582 Views)
thank you so much it worked
now I am trying to plot
Serial.println("$,2232,32.23,96534,826.2232,8,58,3,-19.2,38.6");
delay(1000);
Serial.println("#,4562,56.53,78965,25.23,25.6,58");
delay(1000);
this where $ and # are starting checking symbol of the whole data whether it is correct value or garbage one
if $ or # is found than only it will plot
(3,577 Views)
