Not getting output from pic-servo board
Greetings everyone and thanks in advance. I wish to use a Pic-Servo SC controller  board (http://www.jrkerr.com/) to control a single stepper motor, using LabView. Here's what I've done so far:
-I already have installed 32 and 64 bit LabView (2011) and tried the test program in both
-VISA controller is properly installed
-USB to Serial FT232R converter is also installed, and configured in 19200 baud rate
-COM3 port is shown as the assigned port for the controller, and selected as such in LV
So far, I have managed to get the test program to run without communication errors, but upon sending any commands to the motor, it is completely unresponsive and behaves like it has no current or controller attached, despite it being configured in the basic 1-motor setup specified by Jrkerr site.
Any help, comment or suggestion about how I could manage to get the motor moving will be welcome.
(5,220 Views)
I would not be surprised at all that you are getting nothing.  The device is RS-485  (Wrong USB to Serial adaptor)
(4,988 Views)
I see... what puzzles me is, I can communicate with the board, and when I turn the motor dial manually the encoder reacts and I actually get a response. Either way, what controller could you suggest?
(4,969 Views)
Van you attach the manual? I get an error every time I try. I'm not convinced that it is RS485 from the brief product description. It talks about buying a RS232-RS485 adapter to communicate to multiple controllers.
(4,954 Views)
the on device chip is http://www.linear.com/product/LTC491
I'm fairly certain the USB to RS-232 converter isn't helping
(4,924 Views)
